Leaking swivel and droning noise
  • paradox1001
18 Apr 2018 07:54 #191850 by paradox1001
Leaking swivel and droning noise was created by paradox1001
Hi guys
Last couple of days I’ve started noticing a slight droning noise from the front left
Suspected it may be the wheel bearing starting to go.
I’ve just taken a quick look underneath and the swivel is leaking an oily/greasy residue
What is likely to need replacing?
18 Apr 2018 10:18 #191857 by Lambert
Kingpins and if it's noisy possible wheel bearing. All how to guides available in wiki.
The following user(s) said Thank You: paradox1001
  • paradox1001
18 Apr 2018 16:58 #191872 by paradox1001
Replied by paradox1001 on topic Re:Leaking swivel and droning noise
Lambert wrote: Kingpins and if it's noisy possible wheel bearing. All how to guides available in wiki.
Thanks for the reply
I have no steering shake at all and it leaks without been driven
So could it still be kingpins?
I completely cleaned it up and this is how it looked after 30 mins
  • paradox1001
18 Apr 2018 17:12 #191873 by paradox1001
This is how it looks after a 5 mile drive
Can the oil get to the wheel bearing and wash the grease out?
  • paradox1001
18 Apr 2018 17:13 #191874 by paradox1001
paradox1001 wrote: This is how it looks after a 5 mile drive
  • Venter
18 Apr 2018 17:52 #191876 by Venter
Replied by Venter on topic Re:Leaking swivel and droning noise
The kingpin bearing kits come with a new axle oil seal, might as well just change the whole lot if you're going to have to open it all up anyway
Time to create page: 0.156 seconds
