2" Body Lift
- mdog18
13 Apr 2018 16:19 #191663
by mdog18
2" Body Lift was created by mdog18
Hi guys,
I've been doing some research on 2" body lifts and there seems to be some conflicting information regarding whether it is necessary to fit extended brake hoses and steering spacers in order to successfully fit a 2" body lift.
Can someone confirm whether this is necessary or not as I have no experience fitting body lifts!
Thanks,
Matt
Thanks,
Matt
- Thank you received: 706
14 Apr 2018 09:09 #191677
Replied by jackonlyjack on topic 2" Body Lift
spacers yes
if you're removing the anti roll bar then it would be a good idea to fit a longer hose nearside front
as this brake hose passes through inner wing other hoses remain with chassis
I have a new spacers i'm not using £20 posted
Jack
Jack
The following user(s) said Thank You: mdog18
- mdog18
14 Apr 2018 18:47 #191689
by mdog18
Replied by mdog18 on topic 2" Body Lift
Ok great thank you! I already have spacers, thanks anyways
Time to create page: 0.082 seconds
