clunking noise only from take-off
- G-rae
12 Apr 2018 15:27 #191623
by G-rae
clunking noise only from take-off was created by G-rae
There is a sound, clunking/heavier than ticking/ratchet like, happens only when pulling off in 1st gear and more prominent when turning left. Had
a mechanic have a look and he initially thought cv joint but now reckons it could be a chipped tooth in the gearbox! Any ideas?
12 Apr 2018 17:07 #191625
Replied by Riccy on topic clunking noise only from take-off
What year of Jimny is it?
If before 2005 (not VVT/with stick shift 4x4) then is more likley to be the transfer box than the R7me gearbox (T-box chain slipping sounds like you describe), would be under load setting off or if booting it in 1st or second.
after 2005 & VVT/push-button 4x4 would be the R72 gearbox (which seems to be the current fashionable thing to fail).
The following user(s) said Thank You: G-rae
- G-rae
12 Apr 2018 18:20 #191633
by G-rae
Replied by G-rae on topic clunking noise only from take-off
It's a 2000 Jimny. Will that mean it'll need a new/second hand T-box? If I continue to drive will it eventually seize. Will it be expensive to have fixed. You may notice I have no idea on these things!
12 Apr 2018 18:26 #191634
Yes (if thats the cause). And yes & no. If the t-box chain fails then it all depends. more likley its slack and gears are worn so would continue to run but get worse and eventually slip all together. If the chain breaks then it could be a brown trouser moment :laugh:
Take the front and rear props off the t-box, put gearbox in neutral and spin the input prop (intermediate prop) to see what sounds you get from it. drain the oil and see whats stuck on the magnetic plug (but check that the filler plug can be undone before draining it!)
13 Apr 2018 06:54 #191649
by Busta
Replied by Busta on topic clunking noise only from take-off
The CV joints are only turning when you're in 4wd, so unless you are using 4wd on the road it won't be that.
I've never heard of a tooth in the gearbox chipping.
When my transfer case chain stretched and started skipping teeth it was quite loud and shook the whole car. It happened when pulling away and on hard acceleration in 1st and 2nd.
- G-rae
13 Apr 2018 19:51 #191669
by G-rae
not quite into this computer technology stuff, my screen tells me I'm responding to 'Busta' (which I am, but also responding to Riccy....... but hey..........I'm hoping you'll both be able to read if interested). To Riccy, if I was who I dreamed I could be, I would take your advice to the 't' and do the test you advise. I unfortunately don't have much joy when doing things myself mechanically and therefore have learnt to take my vehicle to a 'professional' mechanic anything that only in my imaginary world would be done perfectly by myself! To 'Busta', I also had never heard of a tooth chip in the gearbox making this kind of noise hence me starting this post. Any rough figures on how much this thing will cost me to have fixed? How much time do think I have before I may get this brown trouser moment!!!!!!
Time to create page: 0.091 seconds
