Another Sensor Question.
  • Vella
09 Aug 2018 15:16 #194948 by Vella
Replied by Vella on topic Another Sensor Question.
Hello all, have a similar problem on a 2001 jimny too. Lost key had another one made and after two weeks of running aroung it just missed and turned off. Wouldn t restart again since then. I decided to change crank and cam sensors after comparing this problem to other problems on forum and discussing with local auto elec. But did not fire up neither with the new sensors. Any help please?
  • Vella
09 Aug 2018 15:26 #194949 by Vella
Opened up he common rail and fuel is coming and there is a spark also. Cam turns when cranked, hence timing belt is still there... i m loosing my mind!
  • mickt
09 Aug 2018 16:32 #194952 by mickt
Replied by mickt on topic Another Sensor Question.
You really should have started a new thread to make it easier for yourself and members. Try rebooting the engine ECU by unplugging and refitting its connector with the electrics off of course.
  • Miniman
09 Aug 2018 17:45 #194954 by Miniman
Replied by Miniman on topic Another Sensor Question.
You need to ask someone who has a PC that you can plug into the Jimny. It will bring up any fault or error codes and I would start from there. Maybe your local garage can do it for a small fee. Worth asking. It makes things alot easyer than guessing. It gets a bit expensive if you guess,
Dan
Time to create page: 0.088 seconds
