Spring lengths
  • Mooser
09 Apr 2018 15:35 #191483 by Mooser
Spring lengths was created by Mooser
Recently bought another jimny it’s been lifted I think it’s 3” but I’d like to be sure as it’s broken both front springs and don’t wan to order +3” springs if it’s only a 2” lift
09 Apr 2018 17:41 #191487 by Lambert
Replied by Lambert on topic Spring lengths
There's so many different types of spring that offer something approximate to a 3 inch lift, some are soft and long others are shorter but stiffer it's a minefield. How tall is the arch to hub gap on the none snapped end of the car, that will be a good place to start on matching the height. Also and this is just my opinion but it would be a lot easier to get a set of 4 springs from one source and start again with a known quantity.
09 Apr 2018 18:22 - 09 Apr 2018 18:25 #191488 by Riccy
Replied by Riccy on topic Spring lengths
Lambert is correct, an unknown spring will be hard to match. If one has snapped, then the chances are its a cheap-n-nasty kit so best replaced anyway. (or a really old and past it now kit)
example of the size difference: orange is Trailmaster 2" petrol, green is Zanfi 3" diesel, but a lot longer without load on it.
Last edit: 09 Apr 2018 18:25 by Riccy. Reason: past it coment
  • Mooser
09 Apr 2018 21:03 #191495 by Mooser
Replied by Mooser on topic Spring lengths
It looks to be the pro comp kit that’s on it I considered welding one of the springs back together to measure the gap hub to arch but unsure how accurate it would be after that much heat
Time to create page: 0.083 seconds
