Transfer box exchange
- Stumpjumper
27 Mar 2018 19:34 #190929
by Stumpjumper
Transfer box exchange was created by Stumpjumper
I'm hoping to switch transfer boxes on my 2005 pre vvt Jim over Easter. It's another attempt to rid myself of some irritating resonance I've been suffering for yonks.
As a means of making my life easier ....could you tell me if the alloy supports for the transfer box have to be unbolted, or can the box be manhandled out of the way by just unbolting the three rubber mountings holding the supports to the chassis.
- Thank you received: 706
27 Mar 2018 19:43 #190932
Replied by jackonlyjack on topic Transfer box exchange
Yes just remove all the prop bolts unclip wires
Remove the knob then the three rubber mount nuts then wiggle it out
- Stumpjumper
27 Mar 2018 20:19 #190933
by Stumpjumper
Replied by Stumpjumper on topic Transfer box exchange
Yeah thought that would be the case, cheers Jack
28 Mar 2018 07:15 #190952
by facade
Replied by facade on topic Transfer box exchange
I removed the knob, propshafts and cables, had massive trouble undoing the 3 nuts, which wrecked the rubbers (think I had to nutsplit 2 off) then supported the weight of the box and removed the left single point mounting with the 4 bolts that you can get off.
still took a bit of wriggling to get it out, and it is heavier than you think when you are lying on your back reaching up.
- Stumpjumper
28 Mar 2018 09:09 #190956
by Stumpjumper
Yeah, I'm always amazed I get anything done in what little space we've got. I was under there last night ,wd40 & 14 mill socket in hand, slackened off the three cradle nuts soaked em & did them up again. The rubber blocks look OK so no point changing them. I checked the rear gearbox mount at the same time & wondered why the mount feels very unforgiving, could be transmitting vibes to the chassis?
28 Mar 2018 12:07 #190964
by facade
While it is off, remove the rubber blocks completely, clean all the corrosion off the face of the alloy mounts, lacquer, or paint the face to stop it corroding again, and refit.
What happens is they corrode massively between the steel face of the rubber block and the alloy mount, build up a huge layer of aluminium oxide, bend the flat plate on the mount, and pull the nut out through the alloy, cracking it.
Time to create page: 0.095 seconds
