Squealing at 40mph+
- petejones69
28 Mar 2018 20:28 #190997
by petejones69
Replied by petejones69 on topic Squealing at 40mph+
Took it for a spin this evening. Did find that after a cold start the squealing begins when I get to around 40mph, but once warm, it doesn't begin until around 50mph. The electrics made no difference - turned the lights on and the fan up to full.
However, I do need to replace the front wheel bearings. Could this be making the squealing? It's definitely coming from the front end.
- petejones69
11 Jun 2018 20:03 #193381
by petejones69
The bugger is still squealing after I had two belts changed when it went in for an MOT. So I guess it's a misalignment. Is this easy to fix?
16 Jun 2018 08:39 #193520
by kirkynut
Replied by kirkynut on topic Squealing at 40mph+
Check the crank pulley as they have a rubber damper that deforms. It's the only pulley that can come misaligned because the rest are solid.
The following user(s) said Thank You: petejones69
Time to create page: 0.094 seconds
