Advice on knocking on rear end
- Thank you received: 77
07 Mar 2018 13:02 #190074
by robs5230
standard jimny - for now
Advice on knocking on rear end was created by robs5230
Just looking for a few suggestions.
Even the slightest bump in a road sends a bone jarring knock through the back of the jimny. Feels like its running with no tyres
Looks to be no play in the radius arms and I know at least one rear shock is suspect so I've got a pair of replacement shocks on the way.
Anything else I need to have a look at ?
Thanks
Thanks
- Thank you received: 2004
07 Mar 2018 13:59 #190077
Replied by Lambert on topic Advice on knocking on rear end
I have had similar experiences with no obvious play in a radius arm bush but replacement cured the knock.
The following user(s) said Thank You: robs5230
07 Mar 2018 14:02 #190078
Replied by Daniel30 on topic Advice on knocking on rear end
Exhaust hangers? Had a knocking on mine - hanger had gone above the rear silencer.
07 Mar 2018 16:34 #190084
by robs5230
Replied by robs5230 on topic Advice on knocking on rear end
oddly enough, the exhaust is new but been put on badly and knocking most of the length including the back box. Easily sorted though.
07 Mar 2018 16:36 - 07 Mar 2018 16:37 #190086
by robs5230
Its more of a bang when the car goes over bumps rather than a knock. Almost like no suspension. Dont think its the arms. I'll see how it goes after changing the rear shocks.
Last edit: 07 Mar 2018 16:37 by robs5230.
- 1066Boy
08 Mar 2018 07:34 #190109
by 1066Boy
Replied by 1066Boy on topic Advice on knocking on rear end
Had this on mine recently. It was one of the lower shock bolts. It was tight but managed to get another 1/2 turn on it, problem solved. Hope yours is as simple.
