Hand brake cable lever
- Iaitoo
07 Mar 2018 11:38 #190061
by Iaitoo
Hand brake cable lever was created by Iaitoo
Hello
How is the cable connected to the lever?
Replacing the cables, so I need to get them loose. My neck is killing me, and I can't fiddle to much with it before the pain is to hard to bare.
Tried looking at it, and didn't see any obvious way to get them off, bit rusty and dirty up under there
07 Mar 2018 11:52 #190064
by Busta
Replied by Busta on topic Hand brake cable lever
I've never removed them but I'm fairly sure your answer lies beneath the plastic trim inside the car.
- Mraz
07 Mar 2018 14:44 - 07 Mar 2018 14:44 #190081
by Mraz
Replied by Mraz on topic Hand brake cable lever
Exactly. There's an M8 or M10 nut you can see from above the brake lever, used to tighten the slack out of the cables. Just undo it.
Last edit: 07 Mar 2018 14:44 by Mraz.
- Iaitoo
07 Mar 2018 15:00 #190082
by Iaitoo
Replied by Iaitoo on topic Hand brake cable lever
- MadsV
07 Mar 2018 18:22 #190090
by MadsV
Replied by MadsV on topic Re:Hand brake cable lever
Loosen the two bolts you see to the right in the photo, you can see them from inside the car
- Iaitoo
07 Mar 2018 19:51 #190095
by Iaitoo
Replied by Iaitoo on topic Re:Hand brake cable lever
Tar jeg ikke av hele dingsen da? Jeg vil kun ha ut de to vaierne til brekket. pga jeg har nye. Resten av mekanismen vil jeg ikke tulle med
Kun vaierne fra trommel og frem. Bildet er fra feil bil tror jeg. Mener det er en vitara.
Time to create page: 0.095 seconds
