Rear shock top mount
- Fs69
06 Mar 2018 17:06 #190027
by Fs69
Rear shock top mount was created by Fs69
Hi all, I'm after a bit of advice, I've started to replace both rear shocks however the top stud seems to have welded itself to the inner steel ferrule in the shock and therefore I am unable to undo the the stud through the mounting bracket, any advice will be very much appreciated.
Thanks
Mark
Thanks
Mark
07 Mar 2018 08:13 #190047
by robs5230
standard jimny - for now
Replied by robs5230 on topic Rear shock top mount
I have the same job to do on an old jimny I've bought and pretty much expecting the same issues.
Couple of options. Get some proper penetrating oil on the bolt for a couple of days to see if it frees up, get some heat on it to melt the bush, or whip it round a garage and get them to loosen it with an impact wrench.
I did the same job on one about 6 years ago. From memory they are hard to get to (but I've got a bad memory).
I'll be going penetrating oil then impact wrench.
07 Mar 2018 11:56 #190065
by Busta
Replied by Busta on topic Rear shock top mount
Don't think there is access for an impact driver and as the bush is made from rubber it will burn rather than melt- not ideal especially next to the fuel tank filler!
I'd be getting a long spanner or breaker bar on it and being forceful. Something will give- either the inner bush sleeve on the bolt of the bush will turn in the shock.
07 Mar 2018 16:47 #190087
by robs5230
mmm I did think there was a shortage of room. Mine will be getting a liberal washing of plusgas for the next couple of days then out with the breaker bar saturday
- Fs69
07 Mar 2018 19:02 #190093
by Fs69
Replied by Fs69 on topic Rear shock top mount
I had given it a dowsing of wd40, managed to get a ratchet on it, it was very tight, when I'm undoing the stud it seems to be pushing open the welded bracket/clamp that the shock bush fits into instead of pushing itself out as its slackening off, very frustrating.
Time to create page: 0.092 seconds
