gearbox propshaft removal
- rexthecat
03 Mar 2018 16:35 #189890
by rexthecat
gearbox propshaft removal was created by rexthecat
Thinking I might need to replace a UJ on the shaft between the gearbox and transfer. Any tips on removing it? Is it just a case of unbolting it from the transfer box and sliding it out from the gearbox then reverse to refit?
cheers
cheers
03 Mar 2018 17:20 #189893
Replied by Riccy on topic gearbox propshaft removal
put the back of the car on ramps to make the gearbox oil go to the front of the box. it will all fall out when the prop is pulled out otherwise.
other than that its just 4 bolts onto the transfer box and pull out of the gearbox. You might need to remove the front prop to get to it tho.
- rexthecat
04 Mar 2018 09:36 #189918
by rexthecat
Replied by rexthecat on topic gearbox propshaft removal
grand thanks, guess just chock the front wheels well.
cheers
cheers
Time to create page: 0.079 seconds
