Faint knocking - Rocklobster issue?!
- X88RED
02 Mar 2018 20:38 #189847
by X88RED
Faint knocking - Rocklobster issue?! was created by X88RED
Hi all,
After a day of driving in the snow and Ice I have noticed an annoying noise. I will try and describe it as good as I can do.. so it only happens in 4wd (2wd and 4wd low are fine), I would say it’s most noticeable when going about 30mph, happens when you take your foot off the accelerator after accelerating and then also when you first put your foot back on the accelerator after not accelerating at all. It lasts about 1 second. Hard to describe the actual noise but it sounds like a faint knocking almost. I have only really noticed it after fitting my Rocklobster 5:1 box but then again I have hardly driven in the snow and in 4wd at speed.
Thanks for your help.
Redmond
Redmond
- rexthecat
02 Mar 2018 20:52 #189849
by rexthecat
Replied by rexthecat on topic Faint knocking - Rocklobster issue?!
worth checking the UJ ? Think I need to replace one of mine.
- X88RED
02 Mar 2018 21:07 #189852
by X88RED
Replied by X88RED on topic Faint knocking - Rocklobster issue?!
Forgot to mention the front and rear props are brand new and it’s only the intermediate prop that is old - but even if the UJ was gone in that I don’t think it would only make the noise in 4wd?
- Thank you received: 2004
03 Mar 2018 06:35 #189858
Replied by Lambert on topic Faint knocking - Rocklobster issue?!
Have you looked underneath to confirm something isn't packed with ice? My alloys got full of it after some drifts and on a clear bit of road it was almost undriveable because of the ice affecting the wheel balance, could be something similar?
03 Mar 2018 06:59 #189860
by kirkynut
Replied by kirkynut on topic Faint knocking - Rocklobster issue?!
You have gone back to 2wd as soon as you've got onto a grippy surface again?
Otherwise you could have transmission wind up. We don't have a centre diff you see.
- X88RED
03 Mar 2018 07:51 #189861
by X88RED
No packed ice on the car and I made sure I put it back into 2wd if I got onto any grippy surfaces
Time to create page: 0.101 seconds
