Engine cuts for split second whilst driving
- Sasquatch
27 Feb 2018 18:32 - 27 Feb 2018 18:32 #189738
by Sasquatch
Engine cuts for split second whilst driving was created by Sasquatch
Hi,
I have a 1999 Jimny, over the last couple of weeks on three occasions whilst driving I have had a split second loss of power.
The previous two times it was just once during the trip. Today whilst driving at 50 mph it lost power for a split second three or four times in row then carried on like normal. Since then it has been driving fine.
It does not stall just lose power for a split second then drive like normal.
Would the crank sensor cause this ? Or any other ideas
Cheers Colin
Cheers Colin
Last edit: 27 Feb 2018 18:32 by Sasquatch.
- rappey
27 Feb 2018 18:39 #189740
by rappey
Replied by rappey on topic Engine cuts for split second whilst driving
It could cause it, but so could a cam sensor, a failing coil, a lose wire etc...
There are many things that could be at fault..
Hard to diagnose without the problem occuring during diagnosing.
27 Feb 2018 22:22 #189747
by KJS
Replied by KJS on topic Engine cuts for split second whilst driving
Mine started doing this, then it was losing 2 cylinders for a few seconds. Changed the coil packs and now running properly again. Changed both as the car is 12 yr old and thought if one had started to break down it was likely the other would as well.
Keith
Keith
The following user(s) said Thank You: Sasquatch
- MadsV
28 Feb 2018 06:37 #189751
by MadsV
Replied by MadsV on topic Re:Engine cuts for split second whilst driving
Mine does this sometimes, I just release the gas pedal a second and resume driving. Happens rarely
Time to create page: 0.280 seconds
