Steering wheel rubbing feeling
- gman88667733
24 Feb 2018 21:42 #189674
by gman88667733
Steering wheel rubbing feeling was created by gman88667733
Went to see a 1999 Jimny today and was slightly concerned that when I turned it on full lock to the right, it felt like there was resistance/stiffness in the steering wheel or almost like rubbing? I'm not sure if this is normal. Was my first time driving a Jimny, so am not sure what to expect.
Thanks.
Thanks.
25 Feb 2018 01:09 #189677
Replied by Daniel30 on topic Steering wheel rubbing feeling
Was it in 4 wheel drive high or low
Shouldn't feel like that
- gman88667733
25 Feb 2018 08:51 #189678
by gman88667733
Replied by gman88667733 on topic Steering wheel rubbing feeling
It was definitely in 2WD. It felt odd, there was a fair bit of resistance.
25 Feb 2018 12:58 #189680
by facade
Replied by facade on topic Steering wheel rubbing feeling
If the steering box is adjusted too tight to take out excessive wear in the straight ahead position, it gets tight when it is on full lock. Maybe this is the problem?
- Johnniehec
- Thank you received: 56
26 Feb 2018 22:51 #189722
by Johnniehec
Replied by Johnniehec on topic Steering wheel rubbing feeling
Could have been a seized or stiff swivel joint, on the connection rod between the column and steering box, I've had that.
26 Feb 2018 22:54 #189723
by kirkynut
Replied by kirkynut on topic Steering wheel rubbing feeling
King pin bearings.
Time to create page: 0.112 seconds
