Gearbox issue, 2007 manual
- TheGingerWizard
23 Feb 2018 09:51 #189641
by TheGingerWizard
Gearbox issue, 2007 manual was created by TheGingerWizard
Hi guys,
Bit of a weird one with the Jimny, im getting a heavy grinding followed by a loud clunk from the front then all is fine! It only happens when i first move off in the car and at slow speed, once its done it drives perfectly fine, no issues. It will stop if i reduce speed slightly or if i select 4wd and then go back to 2wd. All the 4wd system works fine, i have changed the gearbox oil but it doesnt seem to have made a difference.
Any ideas? I have had a search but cant find anything specific
Thanks in advance,
Matt
Thanks in advance,
Matt
- TheGingerWizard
23 Feb 2018 09:52 #189642
by TheGingerWizard
Replied by TheGingerWizard on topic Gearbox issue, 2007 manual
Forgot to mention, it doesnt happen every time, maybe 7/10.
Thanks
Thanks
23 Feb 2018 18:34 #189645
Replied by Riccy on topic Gearbox issue, 2007 manual
i had this with 215/75 tyres at one point when reversing around corners sometimes (was catching tyres on the front bumper),
otherwise i would start looking at the front vac hubs as that sound a likely culprit. This would be prevalent when using it in 2wd after a 4wd session.
finally the transfer box and diff are the next things to check over
23 Feb 2018 18:48 #189646
Replied by mlines on topic Re:Gearbox issue, 2007 manual
A short but loud "machine gun" noise could be transfer chain slip. Try a hill start to see it it gets worse/more consistent
23 Feb 2018 20:40 #189647
Replied by Daniel30 on topic Re:Gearbox issue, 2007 manual
The front hubs OK? could they not be disengaging properly or not out enough and then catching again after a few miles
- TheGingerWizard
24 Feb 2018 12:17 - 24 Feb 2018 12:18 #189664
by TheGingerWizard
Replied by TheGingerWizard on topic Re:Gearbox issue, 2007 manual
Sounds just like a chain slipping on a sprocket. Is the chain a changeable part or is a new transfer box required? Is it a big job? Im fairly handy with a set of spanners so would be doing it myself.
Many thanks,
Matt
Many thanks,
Matt
Last edit: 24 Feb 2018 12:18 by TheGingerWizard. Reason: Thought i was replying to a specific reply
