M series stroker
- Thank you received: 2004
12 Feb 2018 05:07 #189277
M series stroker was created by Lambert
Hi another of my odd questions. Reading on the internet it appears that the main difference between the 1.3 and the 1.6 is the crank throw at least for displacement. I know it would be a lot of work but if for instance the motor was already apart is it possible to do a crank swap or is it more complex than it sounds? Yes I know it would be a lot easier to get a 1.6 and replace it whole but what fun is that?
12 Feb 2018 05:16 #189278
Replied by Lambert on topic M series stroker
Also, and this is a lot of work, is it possible to get the additional 5mm diameter out of the cylinders of a 1.6 to get up to 1.8 or indeed beyond that?
- Jimx5
12 Feb 2018 07:19 #189279
by Jimx5
Replied by Jimx5 on topic M series stroker
As a minimum you would have to replace/swap the pistons ( if they are interchangeable) as the extra throw on the crank would drive the pistons into the head.
12 Feb 2018 07:28 #189280
If getting to 1.8 is possible i think that would be interesting.. You could also get a high compression 1.8 as most european m16a have 11.1 CR and the 1.8 has 9.5 CR.
However the M16 do have a higher cylinder block and i guess more crank throw than the M13 so i guess the M16 is already maxed out except for the bore.
There is also a M15 sport engine and that could possibly be a M13 with more crank throw..
Cost compared to what you get is of course way beyond reason wich makes it kind of fun to do i guess.
Replied by yakuza on topic M series stroker
Lambert wrote: Also, and this is a lot of work, is it possible to get the additional 5mm diameter out of the cylinders of a 1.6 to get up to 1.8 or indeed beyond that?
12 Feb 2018 08:55 #189282
by Busta
Replied by Busta on topic M series stroker
I looked into all this before doing a 1.6 swap and it is indeed much easier to just swap the engines. The 1.6 engine is a stroked 1.3 with a taller block. To achieve the same in the 1.3 block you would need custom pistons and if you are going to that much effort why penalise yourself by using the block with least potential? Spend the money on bike throttle bodies for the 1.6 instead...
12 Feb 2018 09:08 #189283
Hmmm. I think I could have a plan forming here. A 1.6 bored to 1.8, with forged internals and some induction assistance. Like you say Busta 1.6s are quite cheap as a base and put the money into the guts of it. A gearbox eater.
Time to create page: 0.103 seconds
