Engine oil on transmission housing - where from?
30 Jan 2018 14:11 #188979 by asypeer
Hi, I added UV dye to the oil - therefore the oil is greenish..
Anyways, we found out that the leak was probably from the camshaft o ring which dried over time.
5 minutes later with a new o ring fitted and some degreaser to clean the bell housing and I think we are OK now.
30 Jan 2018 15:54 #188984 by Lambert
That would do it!
  • CharlesS
30 Jan 2018 23:14 #189007 by CharlesS
Great find....
UV glowing dye....
I use that to locate leaks in air conditioning, but never tried using that with an engine oil leak.
01 Feb 2018 11:25 #189031 by asypeer
I’m planning to replace the oil soon so I thought it won’t harm to add 20cc for 500km. Finger crossed.
