Rear Panhard
  • Bilmin
23 Jan 2018 11:57 #188754 by Bilmin
Rear Panhard was created by Bilmin
Hello all
After damaging the rear chassis Panhard bracket on my 06 Jinny I welded up a replacement but had to move the hole slightly to the passenger side so this pushes my rear axle to the left about an inch or less so my question is
Is there a rear adjustable Panhard that can be adjusted slightly shorter than normal??
Thanks all
Bill
23 Jan 2018 12:38 #188757 by Lambert
Replied by Lambert on topic Rear Panhard
Not as far as I am aware. They are primarily for lifts which need longer not shorter. Unless someone knows different?
The following user(s) said Thank You: Bilmin
  • Mraz
23 Jan 2018 18:22 #188777 by Mraz
Replied by Mraz on topic Rear Panhard
If you can weld, and it seems so... just shorten the original panhard and weld it back together. Or make it adjustable.
  • Bilmin
05 Feb 2018 06:31 #189102 by Bilmin
Replied by Bilmin on topic Rear Panhard
I saw this rear Panhard on eBay Panhard
Will it fit Jimny as there is a small bend at one end and the brackets on axle and chassis on jimny are on same plane.
Is this for a jimny or is there something I don’t know?
Thankyou
Bill
05 Feb 2018 07:23 #189103 by Lambert
The one in the listing looks wrong but the one in the description looks right. I would be looking for clarity from the seller.
Time to create page: 0.210 seconds
