Cable throttle? Vvt? Newbie!!
- Dannyzook
19 Jan 2018 10:43 #188563
by Dannyzook
Cable throttle? Vvt? Newbie!! was created by Dannyzook
Bit random and also first post so be nice
im looking to buy a jimny in next week or so
ive been looking around 2002-2006 and i know this is the cross over year. Ive a budget of £3000 and looking for a clean one (fed up of having to weld my hilux) so i have a few questions. It will be used as a second car (weekend toy) but also to commute to work when i go out with friends after work (100mile round trip) so needs to be good on the road to and the lanes i use are veryy basic so will mostly be a tarmac tractor.
1) i understand the pre 2005 has a manual transfer case and also different drive ratios. Im wantin to put some 235/75 tyres on eventually, is the newer one still nice to drive (ie gearing wise) or is the older one better?
2) are they both vvt?
3) are they cable throttle?
4) is it true the later ones have a galv body and wear better to corrosion, im going to underseal when i get it but want the cleanest one i can find as a base to start with.
5) how electronic are they? Im going from an old school hilux and before that a 73 beetle. Hahaa.
Thanks in advance.
Danny.
Thanks in advance.
Danny.
- Thank you received: 2004
19 Jan 2018 12:10 - 19 Jan 2018 12:12 #188571
Replied by Lambert on topic Cable throttle? Vvt? Newbie!!
Ok 235s are about as big as any of them will suffer without needing to adjust the gearing with some kind of altered transfer box. It is possible to go bigger but it starts to sluggish. Depending on early or late trimming will be needed without a lift.
Only post 2005 are available in vvt.
All are cable throttle
They all rot, boot floor, behind the headlights are the most notable but they will go anywhere
Not very electronic but still have an ecu so some kind of code reader isn't a bad thing. By modern day standards they're very simple.
How rude I forgot to say welcome to the forum, silly me.
Last edit: 19 Jan 2018 12:12 by Lambert. Reason: Manners.
- Dannyzook
19 Jan 2018 12:32 #188574
by Dannyzook
Replied by Dannyzook on topic Cable throttle? Vvt? Newbie!!
Thanks for reply
And im toying with either 235 (and a 2 inch lift) or 215’s, think ill gauge it after a month of driving it and how it drives etc.
Code reader now on order!! And ill make sure i check those area’s!!
Thanks for your help
Danny.
Danny.
19 Jan 2018 12:40 #188576
No worries. Spend time looking at a good few and get the cleanest standard one you can. You will not regret it.
19 Jan 2018 14:03 #188581
Replied by Daniel30 on topic Cable throttle? Vvt? Newbie!!
Welcome to the forum, if it's a tarmac tractor I would go for the 215
- 1066Boy
19 Jan 2018 17:27 #188584
by 1066Boy
Replied by 1066Boy on topic Cable throttle? Vvt? Newbie!!
Time to create page: 0.105 seconds
