Setting up my winch
  • tim_jimny53
18 Jan 2018 17:16 #188529 by tim_jimny53
Setting up my winch was created by tim_jimny53
Hi all
Have recently purchased a new winch for my jimny....how should I set the battery up ?
Planning on buying a bigger battery to power the lot rather than run a twin battery set up
Any info would be great
Thanks
  • TomDK
18 Jan 2018 17:32 #188533 by TomDK
Replied by TomDK on topic Setting up my winch
What info do you need?
If you buy a new winch it usually comes with all cables, wires and such-
  • tim_jimny53
18 Jan 2018 18:00 #188534 by tim_jimny53
Replied by tim_jimny53 on topic Setting up my winch
What battery’s are people using to run their winch.....odyssey red top???
  • TomDK
18 Jan 2018 18:20 - 18 Jan 2018 18:22 #188537 by TomDK
You mean Optima right?
Both Yellow top and red top works great with winching.
Some speculate that the Yellow top is more suited for winching as it's a deep cycle battery and the red top is a starter battery.
But a winch motor is very much like a starter battery and works great with a red top, as the red top delivers plenty of CCA's and is easily charged. So if you've a good deal on a red top Optima, got for it.
What winch?
You're probably just a good going with a cheaper Varta AGM battery or similar.
Last edit: 18 Jan 2018 18:22 by TomDK.
  • tim_jimny53
20 Jan 2018 18:37 #188622 by tim_jimny53
Got a goodwinch goldfish 9.5
  • TomDK
20 Jan 2018 23:37 #188646 by TomDK
Awesome winch. Don't come much better than that for budget winches :)
Just use the cables that comes with the winch and follow the instructions.
A good AGM battery with more than 700 CCA's will do :)
Time to create page: 0.099 seconds
