Head gasket replacement
- brumby
18 Jan 2018 11:28 - 18 Jan 2018 11:29 #188518
by brumby
Head gasket replacement was created by brumby
Hi all, new to the forum.
I have a 2008 1.3L petrol Jimny with manual gbox. I believe my head gasket requires replacement as the car is using coolant but there is no visible leak.
The other thought I had was the radiator cap is lifting prematurely and blowing the coolant out although I don't think that this is the case?
The question I have is has anyone on here removed their Jimny cylinder head without removing the whole engine from the vehicle? Or is it easier to just take the engine out?
Your help would be greatly appreciated.
Thx
Thx
Last edit: 18 Jan 2018 11:29 by brumby.
- Jimx5
18 Jan 2018 14:01 #188520
by Jimx5
Replied by Jimx5 on topic Head gasket replacement
I’ve never had to remove an engine to do the head gasket.
Remove your rad cap and top the coolant, start the engine and watch for bubbles or do a compression test.
These are simple first tests but no you won’t need to remove the engine.
- 1066Boy
18 Jan 2018 17:31 #188532
by 1066Boy
Replied by 1066Boy on topic Head gasket replacement
Sounds just like Kates Jimny. Engine pressurising the rad and forcing the coolant through the expansion bottle. Headgasket being changed as we speak.
- mickt
21 Jan 2018 12:14 - 21 Jan 2018 12:15 #188669
by mickt
Replied by mickt on topic Head gasket replacement
If you take the head off don't forget to give it a thorough inspection for cracks and corrosion damage on both head and block. Ensure the new gasket matches the old one and take the opportunity to clean the valves and ports and relap the valves into their seats if of course they are fully serviceable. Don't just get the gasket but get the kit which will include the new valve oil seals too. Also take the opportunity to reverse flush out the coolant system before you put the new antifreeze in. It is a good idea to use new head bolts too.
Last edit: 21 Jan 2018 12:15 by mickt.
22 Jan 2018 22:34 #188736
by Keithy
Replied by Keithy on topic Head gasket replacement
I think it'll be easier if you remove the engine.....I wouldn't fancy doing it in situ.
- Jimx5
23 Jan 2018 07:05 #188743
by Jimx5
I really don't understand your logic....why would you even consider taking the whole engine out?
Time to create page: 0.115 seconds
