4wd simply doesn't work....
18 Jan 2018 09:54 #188512 by Lambert
Replied by Lambert on topic 4wd simply doesn't work....
Yes. The propshaft can't rotate because of the transfer box not having a diff and neither can one wheel so therefore the diff is unable to rotate around either the crown wheel nor the planet or sun wheels effectively locking the remaining wheel. It's how a diff has to work.
  • florinelu07
18 Jan 2018 09:58 #188513 by florinelu07
Replied by florinelu07 on topic 4wd simply doesn't work....
Understood.
Thanks for your patience....
So at a first look that the hubs are not engaging (or a least one).
18 Jan 2018 10:07 #188514 by Lambert
Correct
The following user(s) said Thank You: florinelu07
  • florinelu07
18 Jan 2018 10:22 #188515 by florinelu07
Given that I'll have to remove them from the car, do you have any recommendations regarding the cleaning and greasing procedure of the locking hubs?
Recommended lubricant?
18 Jan 2018 10:30 #188516 by Lambert
Therr might be a specific grease but I just used a little bit of the waterproof one i use on the kingpins, only a little bit though, just a dab will do.
  • florinelu07
18 Jan 2018 11:11 - 18 Jan 2018 11:12 #188517 by florinelu07
and hopefully the last question: which vacuum tube goes into the upper position into the wheel hub? VSV2 (locking) or VSV1(unlocking)
Last edit: 18 Jan 2018 11:12 by florinelu07.
Time to create page: 0.092 seconds
