replacement antenna FM/DAB
16 Jan 2018 11:03 #188439
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
replacement antenna FM/DAB was created by Mike G
Has anyone ever fitted a replacement antenna that covers both FM and DAB in the original roof fitting? My windscreen is starting to fill up with electronics kit and it is starting to look like I'm either surveying the roads or some sort of spy.
- Thank you received: 2004
16 Jan 2018 11:09 #188440
Replied by Lambert on topic replacement antenna FM/DAB
When I used to fit such things there was always a separate antenna for each. That was years ago though so it could well be a thing now, but I have never looked.
16 Jan 2018 11:19 #188441
by Mike G
Replied by Mike G on topic replacement antenna FM/DAB
Yes, I have the separate antenna thing at the minute, but there are dual function antennas out there. The best I've come up with so far is
this splitter
, however, I think it would probably need to be amplified on the DAB side and that doesn't have amplification. Also, I need to replace my antenna as it's old and a bit knackered and looking on ebay, they cost £28.90, at the cheapest!
I just wondered if there was a certain fitting type that describes the jimny roof hole size, which I could then search for. Perhaps an adapter plate for one of the 'universal' DAB/FM antennas?
16 Jan 2018 11:51 #188442
by Mike G
I've emailed a few places, hopefully will hear back from them, but I won't hold my breath on this one.
Time to create page: 0.106 seconds
