slack steering issue
- CharlesS
In the states I own a 1998 Jeep Cherokee with a 5.5" lift and 33" tires. The vehicle originally came with shims to adjust caster, but are no longer there; I installed fully adjustable upper and lower control arms with geometry brackets, and 1 ton steering. Some responses I get are: How do I adjust this, what is this or is this factory?
You definitely need to get an assistant to assist in troubleshooting what is loose or worn out.
CharlesS wrote: Most alignment shops do not know how to work outside the bubble when it comes to lifted off road vehicles and alignments.
Yeah it was a tyre spot who were not used to modified 4x4. even the more experienced place i normally use still take a few looks before doing anything :dry:
Jacking up and playing with the wheels gives a slight (and very slight) knock or rattle from the swivel, which points me towards wheel bearings
Ironically I used to have a lifted 88 SWB Jeep Cherokee when i lived in Nova Scotia. It was pretty good in the local sand quarry, but pants in snow or on highways! Also had a Subaru legacy which was the best
My steering box has this slack/play. A lot of play in the middle, and tight in the ends at full left or right turn. Not much use trying to tighten the nut so i guess it is just worn out in the middle there... 100000km 2005 jimny. I have a spare so will be changing it one day..
Busta wrote: Unless you have very worn wheel bearings then the only thing affecting the tracking is the track rod, so why they couldn't do it is a bit of a mystery. Play in the drag link, panhard, steering box etc would make the steering vague and probably knock a bit, but it would have zero effect on their ability to set the tracking.
You were right Busta! solved it now hopefully. The wheel bearings were ok after all...
Got myself some spare complete swivels/hubs courtesy of the ever helpful James Priestly. When i had drilled the track rod holes out on the carriers for the larger trailgear steering bar track rod ends (beefy toyota LJ70 rod ends), i had drilled too much, making them a tiny bit loose. The spare swivels have been drilled correctly this time and all is well.
For peace of mind i have put new wheel bearings, kingpin bearings, seals, grease, etc in whilst it was all apart. Yet another lesson learnt with the modifying stuff!
In January I replaced the swivels and sorted out the HD links properly. That did improve it, but has gotten steadily worse for a few months.
Last outing with the winch bitch having a drive, he was complaining that the steering was really vague.
Checkover last weekend and found all the radius arm bolts were slack. Tightened the life out of them with a 2ft breaker bar and what a difference now! Miles better, doesnt wander and is sharp prescise steering
Only problem is that now its all nice and tight, I get bad wobble from the unbalanced tyres (well they were balanced but somehow the weights have all gone :whistle: ).
Balance beads are the way, but where do i get them from and how much weight is needed? (31x10.5r15 tyres, not remoulds).
