Badge positions
11 Jan 2018 13:47 #188283
Badge positions was created by mlines
My Jimny has had a hard life and this time around we are re-building to more of a shiny princess. It has never had badges on it (probably removed almost immediately in its life as i believe it was a KAP re-build of a damaged car, the KAP build receipts are dated 6 weeks after it was registered at a dealer)
So I now have the badges to hand, can I have a couple of measurements from someone with a ruler who can pop out to their car.
1. Left Door side edge to edge of first letter of Suzuki badge
2. Door bottom edge to edge of bottom of Suzuki badge
3. Right Door side edge to edge of last letter of Jimny badge, the top point corner of the "Y"
2. Door bottom edge to edge of bottom of Jimny badge, the base of the letter "M"
Thanks
Thanks
- Cameronmike
11 Jan 2018 16:53 #188285
by Cameronmike
Replied by Cameronmike on topic Badge positions
1.24mm
2.189mm
3.34mm
4.197mm
2.189mm
3.34mm
4.197mm
11 Jan 2018 18:22 - 11 Jan 2018 18:22 #188289
Sent from my Nexus 6P using Tapatalk
Replied by mlines on topic Re:RE: Badge positions
Thanks, I presume you do not mean mm, more like 21.89cm etc?Cameronmike wrote: 1.24mm
2.189mm
3.34mm
4.197mm
Last edit: 11 Jan 2018 18:22 by mlines.
- Cameronmike
11 Jan 2018 19:33 #188290
by Cameronmike
Replied by Cameronmike on topic Re:RE: Badge positions
na sorry is mm, just the 2.189mm would be the 2. to correspond to the second lot of measurements and then the 189mm, bit unclear now that I look at it.
11 Jan 2018 21:45 #188292
Many thanks for sorting for me
Replied by mlines on topic Re:RE: Re:RE: Badge positions
Great, I see nowCameronmike wrote: na sorry is mm, just the 2.189mm would be the 2. to correspond to the second lot of measurements and then the 189mm, bit unclear now that I look at it.
Time to create page: 0.125 seconds
