JImny - correct gear ratios
10 Jan 2018 07:18 #188221 by Lambert
Replied by Lambert on topic JImny - correct gear ratios
Yeah I do that with all my vehicles, better than finding out the hard way with a speeding ticket.
  • florinelu07
10 Jan 2018 10:19 #188229 by florinelu07
Replied by florinelu07 on topic JImny - correct gear ratios
Tacho shows the correct speed - just validated it with Waze on a 10 km route.
So the question remains opened.... do I have the corect gear ratio?
10 Jan 2018 10:38 #188232 by Lambert
So at 80 kmh you actually have a lower engine speed. That's good as it will be using less fuel. All good.
10 Jan 2018 10:42 #188233 by Busta
Replied by Busta on topic JImny - correct gear ratios
The car doesn't know what size wheels it has. Unless the speedo has been re-calibrated, indicated speed is simply a factor of the rpm of the transfer case output shaft. So we can rule variations in tyre size or the fitting of a diff with a different ratio out of the equation.
I'm fairly sure the early r72 gearbox ratios are close to or the same as the pre-vvt gearboxes, so even if they had fitted a completely different gearbox it would not be possible to make the gearing longer. However, I heard someone mention recently that 5th in the new Jimnys was like 4th on older ones, so there may have been some changes made more recently, perhaps driven by emissions requirements.
You must have the correct gear ratio as, apart from replacing your transfer box with a manual one, there is no way of making it longer. And it seems the newer Jimnys may well have shorter gearing. Now we need other owners of VVT Jimnys to confirm their model year and speed at 3000rpm in 4th and we can work out when it changed. And maybe somebody can dig up some gearbox and diff specs to see where in the drivetrain the change has been made.
10 Jan 2018 11:08 - 10 Jan 2018 11:44 #188237 by mlines
Replied by mlines on topic JImny - correct gear ratios
As stated, the speed DISPLAYED is derived from a measurement of the rotation of the transfer box output shaft.
The speed ACHIEVED is a function of the differential ratio and tyre diameter.
RPM of engine for a given speed is the combination of gearbox, transfer box and differential ratios
You can see the information I have so far here:
www.bigjimny.com/mediawiki/index.php?tit...erential_information
(updated with gearing)
Last edit: 10 Jan 2018 11:44 by mlines.
10 Jan 2018 11:47 #188240 by yakuza
Replied by yakuza on topic JImny - correct gear ratios
The analogue speedometer is a friction based device so there will be variations from car to car in addition to the obvious tire difference.
Time to create page: 0.176 seconds
