JImny - correct gear ratios
11 Jan 2018 12:35 #188280
Replied by mlines on topic JImny - correct gear ratios
Its the differential ratio
- florinelu07
11 Jan 2018 13:11 #188281
by florinelu07
Replied by florinelu07 on topic JImny - correct gear ratios
ooooooo
I have to say that till now I haven't thought about it....
So first ratio comes from the selected gear, second ratio form the transfer case and third from the diffs (fur sure these last two ratios are identical).
11 Jan 2018 13:38 #188282
Yes,
So for example
2005 VVT manual gearbox Jimny, engine at 4000 RPM and in 5th gear High Ratio
Gearbox input = 4000 RPM
Gearbox ratio = 1
Gearbox output = 4000 RPM
Transfer box input =4000 RPM
Transfer box ratio = 1
Transfer box output = 4000 RPM
Diff input = 4000 RPM
Diff ration = 4.3
Diff output = 465 RPM
Wheel input = 465 RPM
Wheel diameter = 28 inches
Road speed = 77.7 miles per hour
2005 VVT manual gearbox Jimny, engine at 3000 RPM and in 1st gear Low Ratio
Gearbox input = 3000 RPM
Gearbox ratio = 4.425
Gearbox output = 678 RPM
Transfer box input =678 RPM
Transfer box ratio = 2.002
Transfer box output = 338.6 RPM
Diff input = 338.6 RPM
Diff ratio = 4.300
Diff output = 78.5 RPM
Wheel input = 78.5 RPM
Road speed = 1.5 miles per hour
For the road speed calc you can use your maths from school or a web calculator - www.4qd.co.uk/road-speed-calculator/
So for example
Gearbox ratio = 1
Diff ration = 4.3
Diff ratio = 4.300
11 Jan 2018 17:48 #188288
Replied by Riccy on topic JImny - correct gear ratios
Thats a cracking explanation Martin! Add that below the table in the wiki and it should solve a lot of questions
08 Oct 2020 19:49 - 08 Oct 2020 19:49 #228927
by G0bble
You seem to have a lot of knowledge - Would you kindly help me in this thread - Quaife ATB for Jimny
I have what you folks might know as a Gen2 Jimny (with an Axle ratio of 3.73:1). I am trying to figure out if the Axle ratio on my car is exactly the same on the following models which the ATB LSD has been know to fit - Jb43, JB74, the 1995 Samurai and the 1998 UK Jimny. My car is a MG413W which is an in-production version of the Gen2 Jimny in India also known as the Maruti Gypsy. I could not find the Axle ratios on the page you linked hence my post.
I don't want to buy an expensive part with international shipping and pay customs duties on top only to find it is not compatible.
Thank you for your inputs on this.
Replied by G0bble on topic JImny - correct gear ratios
Sir,mlines wrote:
You can see the information I have so far here:
www.bigjimny.com/mediawiki/index.php?tit...erential_information
Last edit: 08 Oct 2020 19:49 by G0bble.
Time to create page: 0.168 seconds
