2008 vvt idle
- gilburton
09 Jan 2018 16:06 #188170
by gilburton
2008 vvt idle was created by gilburton
Now that the colder weather is here my car is starting to misbehave in the morning after it gets warm with everything switched on.
It's started to stall pulling away if you do not put in a bit more throttle. Turning everything off helps but it's not constant.
Does it just need a good service or is something failing?
09 Jan 2018 16:53 #188176
Replied by Daniel30 on topic 2008 vvt idle
Maybe get alternator and battery checked out
- gilburton
09 Jan 2018 17:24 #188179
by gilburton
Replied by gilburton on topic 2008 vvt idle
Yeah I'll check them at the weekend with my multimeter. If the sun comes out it might be sooner lol
I was just wondering if it was a sensor fault as the car starts/runs well otherwise. I assume all is well when the car is still cold as the problem is more really when warm so the sensors must be feeding in more fuel when cold.
- Thank you received: 2004
09 Jan 2018 17:58 #188182
Replied by Lambert on topic 2008 vvt idle
Have you put a live code reader on it to see if it is happy with itself when running?
- gilburton
09 Jan 2018 18:02 #188183
by gilburton
Good idea I do have a reader.
My wife is the main driver so I'm going on her reports lol
- mike83
09 Jan 2018 20:11 #188189
by mike83
Replied by mike83 on topic 2008 vvt idle
Make sure pcv valve Is clean and working. Far left on top off rocker cover is a right angled plug. Google it you'll see what I'm saying. Had an idle issue on mine caused by it.
Pull it out and remove the black pipe from other end, it should rattle and blow through clearly from fat end to barbed end.
Easy to check cheap to fix.
