Crunch time
  • Daniel30
07 Jan 2018 17:32 #188104 by Daniel30
Replied by Daniel30 on topic Crunch time
Pants :D
  • CharlesS
07 Jan 2018 20:06 #188108 by CharlesS
Replied by CharlesS on topic Crunch time
Verify the level of gear lube in the transmission is at the recommended level. If you cannot touch the gear lube at the fill hole; then it may be low. Start looking for gear lube leaks... If fluid needs to be added; make sure to use the proper type (GLI3,4 or 5) fluid.
Some gear lubes have sulfur content that can affect brass/bronzed synchros.
  • Daniel30
07 Jan 2018 20:39 #188109 by Daniel30
There are no leaks that I can see, no marks on my drive
I will get the level checked this week to be sure
Thank you
  • CharlesS
07 Jan 2018 21:06 #188111 by CharlesS
The FSM indicates the level should be just below the inspection hole and 75W/90 gear lube is recommended. The transmission holds approximately 2.5 pints.
  • Daniel30
18 Jan 2018 17:00 #188527 by Daniel30
Well very strange a 20min drive to the mechanic today for the crunch in 2nd problem and it never done it. The plug had no fragments on it either so some fresh oil drive back was sweet as a nut :D
  • 1066Boy
18 Jan 2018 17:24 #188530 by 1066Boy
Replied by 1066Boy on topic Crunch time
Did you check the clutch adjustment at the same time?
Time to create page: 0.121 seconds
