Indicator beep.
- little boghopper
04 Jan 2018 10:35 #188033
by little boghopper
Indicator beep. was created by little boghopper
after the snow came and i went out playing in it laughing at BMs , there is now a beep when i indicate left coming from the rear passenger side,
can i just snip the wire to the buzzer, its probably shorting somewhere thou eh? read a thread on here but didnt have a solution has anyone else this problem?
04 Jan 2018 18:15 #188043
by Busta
Replied by Busta on topic Indicator beep.
Presumably you have a tow bar fitted. It will be shorting out somewhere, either in the 7 pin plug or along the yellow wire that leads to the buzzer. Most likely in the plug.
- little boghopper
04 Jan 2018 18:46 #188045
by little boghopper
Replied by little boghopper on topic Indicator beep.
busta , you rekon that water has got in the plug, it looks brand new, is this a common fault the in the plug bud?
04 Jan 2018 19:41 #188047
by Busta
Quite possibly. They are pretty crap at keeping muck out. Could be wired up badly too. It's an easy thing to check and is where I'd start looking.
- little boghopper
07 Jan 2018 10:21 #188088
by little boghopper
hey busta, the wiring goes up under the rear arches and seem v loose, i can pull them easily, i,ll pull out the rear trim and have a better look , report soon, cheers L.
Time to create page: 0.081 seconds
