BigJimny Diagnosis Required Please - all sorts going on!
- Young Pretender
28 Dec 2017 23:09 #187858
by Young Pretender
Replied by Young Pretender on topic Re:RE: BigJimny Diagnosis Required Please - all sorts going on!
Tbf this is literally the only issue I have ever had with the Jimny (apart from self inflicted stuff). Hopefully fix her up good and back out fighting fit again!
Rubber mallet at the ready
29 Dec 2017 19:25 #187880
by weecorey
Replied by weecorey on topic Re:RE: BigJimny Diagnosis Required Please - all sorts going on!
You didnt mention any belt squeal? Ive never known a belt to be slipping without making noise. The symptoms do seem alternator related and as 11/60 said the sensor was probably damaged by the AA man.
- Young Pretender
29 Dec 2017 19:29 #187881
by Young Pretender
Yes the belt had been squeeling when cold/wet for about a year. Sprayed it with that sticky belt spray a few times.
29 Dec 2017 19:38 - 29 Dec 2017 19:41 #187882
by weecorey
Id say thats the problem then, it could be the pulley is worn on the end of the alternator which cant be changed so you'll need an alternator, it could also be the crankshaft pulley is on its way out which would be a common enough problem, its a 2 part pulley and the binding breaks down between the two causing it to run untrue and belts slip.
And Id say you need a crank position sensor, an other member broke thiers recently while tensioning thier belt.
Last edit: 29 Dec 2017 19:41 by weecorey.
- Young Pretender
30 Dec 2017 11:54 #187896
by Young Pretender
Well they have changed sensor and belt. Said they couldn’t see any evidence of pulleys seizing. It now runs fine when driven but idles REALLY low - 300rpm
It generally stalls but with patience I managed to get it to run at 300rpm. Any ideas folks? Just needs a good run maybe?
Planning on laning tomorrow but don’t think I can if it doesn’t start to idle a bit better
- Young Pretender
30 Dec 2017 12:56 #187898
by Young Pretender
Idling ok now so fingers crossed
Time to create page: 0.234 seconds
