Optima battery question
  • X88RED
28 Dec 2017 18:50 #187843 by X88RED
Optima battery question was created by X88RED
Hello,
Anyone running a yellow or red top optima battery? What’s the difference between the two?
Has anyone got a link to the one I would use as a main battery.. maybe a uprated one as I have got lights, winch etc. I am running a two battery set up but this one will replace my original battery so not powering winch etc.
Thank you!
Redmond
28 Dec 2017 20:13 #187849 by Lambert
Replied by Lambert on topic Optima battery question
My cherokee runs a red top, and other than being expensive to replace I am not convinced it is any better than a normal lead acid one. Yellow tops are are not for starting they are for accessories like winches or monster ice, deep cycle stuff.
29 Dec 2017 09:26 #187865 by facade
Replied by facade on topic Optima battery question
Optima batteries contain purer lead and use an expensive construction technique, the result of which is lower self discharge than a cheap battery. Owners of classic cars like optima red top- but they disconnect the battery in storage.
A red optima is a starter battery. These are only to spin the engine over and then get recharged by the alternator, so they typically only ever go between 100 - 95% charge.
A yellow optima is a deep cycle battery, and is rated for around 200 cycles taking it down to 50% charge (but you can't leave it discharged for long) and recharges quickly, especially on these "modern" cars. like Fords and my Renault Nee-san that charge at over 14V (and blow headlight bulbs all the time......)
You can use a yellowtop as the only battery, especially suited to light winch use, as you can happily let it go down to 50% with the engine running.
In America, ambulances and other emergency vehicles have yellowtop batteries, as they shorten the life of standard batteries when they stand with lights on etc.
As above, if you just want a starter battery, and the slave battery powers everything (do you have a charge-splitter?) then any optima is expensive overkill for the starter, and you need a yellowtop for the slave.
  • Venter
29 Dec 2017 10:12 #187868 by Venter
Replied by Venter on topic Optima battery question
Exide Maxxima MAX900DC-P7502
I've had this on my wish-list for a while, seems to have good specs. Relatively compact, and fulfils both battery roles. Slightly cheaper too.
Anyone with experience of these, or further thoughts as to their quality / usefulness?
01 Jan 2018 22:17 #187953 by kirkynut
Replied by kirkynut on topic Optima battery question
Look at Numax leisure batteries from Tanya Batteries. I've had one on mine for years and used it for winching and left the Jimny unused for weeks but it always starts. I've only got the one battery.
Mine is mounted in a Jimny Bits battery tray. Just consider the height of the battery as the bigger ones will hit the bonnet.
  • CharlesS
07 Jan 2018 21:21 - 07 Jan 2018 21:40 #188113 by CharlesS
Replied by CharlesS on topic Optima battery question
Here in the states the OPTIMA spiral cell battery quality was quite good; approximately 7 years ago the manufacturing plant was moved to Mexico and the quality of the battery declined due to lack of quality assurance. Off Roaders have been in search of a quality replacement battery. Sears & Roebuck has a Diehard Platinum and Gold AGM battery that is a better battery for about the same price if you find them on sale. The ODYSSEY battery is a much better battery than the Optima, but they cost over $125 more.
Hope this video answers your questions about battery differences.
Last edit: 07 Jan 2018 21:40 by CharlesS.
Time to create page: 0.107 seconds
