reversing lights
  • little boghopper
20 Dec 2017 10:13 #187657 by little boghopper
reversing lights was created by little boghopper
hello all, since having the gearbox replaced at 75k, a month later ive noticed the reversing lights dont work, ive fault found the following and i,m now stumped any ideas chaps?
1 no reverse lights when in gear., 2 disconnected connector on the wire coming from the switch on the passenger side of the gearbox .
and shorted it out, lights come on, unscrewed switch bolt on gearbox and tested it with meter and switch works . ??????
so its my thinking there is a rod in the gearbox that needs to push this in when engaged in reverse, but isnt ??? confused , have they fxxked
up on replacing the box? any ideas or can i put a switch in for the mot?
cheers Guys.
20 Dec 2017 12:22 #187664 by maverick
Replied by maverick on topic reversing lights
you don't need a working reversing light for the MOT in the UK ..
Jalapeño, IISY?
20 Dec 2017 12:52 #187667 by mlines
Replied by mlines on topic Re:reversing lights
Did the Ball bearing fall out when they fitted it, not 100% sure there is one but it's a common way of operating a switch
Sent from my Nexus 6P using Tapatalk
  • little boghopper
20 Dec 2017 15:20 #187670 by little boghopper
Replied by little boghopper on topic reversing lights
really maverick????? is thisssss true!! (league of gentlemen!!)
If so brilliant youve just fixed it mate remotely!!
20 Dec 2017 15:22 #187671 by maverick
yes its true
Jalapeño, IISY?
  • little boghopper
20 Dec 2017 15:22 #187672 by little boghopper
Replied by little boghopper on topic Re:reversing lights
hello martin, there is a small ball bearing in the end of the switch, and it all works ok, puzzled,
but if dont need for mot, its staying as is!!
Time to create page: 0.107 seconds
