4 x 4 system
- Molecatcher1957
14 Dec 2017 17:39 #187443
by Molecatcher1957
4 x 4 system was created by Molecatcher1957
Not sure if I should be starting a new thread or tagging this onto the one dated the 12th by myself. The issue relates to the 4wd system on my 2002 Jimny not working. I have ascertained that I have a vacuum to the front hubs on both vacuum pipes but the collars are not pulling on. I have removed the cover on the hub by removing the 6 hex bolts revealing the sliding splined collar inside. I can see how that operates and I can operate that manually and it seems quite free but it wont work via suction. This would indicate a lack of vacuum in the hub but not sure where the loss could be occurring. The strange thing is that both sides are not functioning. The wheel bearing is new so that shouldn't be a problem. Anybody ideas where the problem might be. Any advice would be greatly appreciated.
- Thank you received: 2004
14 Dec 2017 17:55 #187445
Replied by Lambert on topic 4 x 4 system
Take the flex pipes off the hubs one at once and very carefully clean out the ports in the hub with an air line don't go mad with it.
- mickt
14 Dec 2017 20:08 #187453
by mickt
Replied by mickt on topic 4 x 4 system
As I mentioned in your first thread read the guide Martin wrote in the forum. It explains it all in good detail better than snippets from us.
14 Dec 2017 20:34 #187454
by facade
Do this with the black outer hub removed so the air has somewhere to go.
Usually changing the wheelbearing fills the small channels with grease and they don't work until cleared out.
Replied by facade on topic 4 x 4 system
11/60 wrote: Take the flex pipes off the hubs one at once and very carefully clean out the ports in the hub with an air line don't go mad with it.
- Molecatcher1957
14 Dec 2017 21:04 #187456
by Molecatcher1957
Replied by Molecatcher1957 on topic 4 x 4 system
Thanks for the advice given by you and other members ,I will use the air line as advised. Do the o rings and seal in the black hub that go over the end of the driveshaft in front of the bearing to create a seal ever need replacing Molecatcher
15 Dec 2017 10:18 #187479
by facade
Hub cross section
The vacuum to engage the hubs passes through the hollow centre of the stub axle alongside the CV stub, and pulls the diaphragm (20) towards the CV splines. This needs the seal where the CV enters the hub, and the large thin oilseal working on the extended flange of the hub nut to be in good nick.
The disengage vacuum passes through the ball race, and needs the wheelbearing and seals to be in good nick.
Any obvious damage to the seals will help stop it working, there are bound to be some slight leaks with all the rotating parts though.
The teeny weenie ports block with grease when a new wheelbearing is fitted, and can't ever clear really, so have to be blown through (with the black outer hub removed)
