4 x 4 system.
  • Molecatcher1957
12 Dec 2017 14:48 - 12 Dec 2017 14:50 #187373 by Molecatcher1957
4 x 4 system. was created by Molecatcher1957
Sorry guys I started a thread last week regarding my 4 wheel drive system not working and the advice given was to fit manual hubs. This remains an option but I have been like a dog with a bone with this one and have now isolated the problem to the front hubs. I have fitted a replacement solenoid and piping which now gives me a vacuum right up to the point of entry to the hub itself. This isolates the problem to one of the locking collars not pulling on (or does it ?). Does anyone know how the system works in the hub and how technical is it. I have searched the archives and technical info section for info without gain. I seem to be pretty close to solving the problem but any further advice would be appreciated. Many thanks molecatcher
Last edit: 12 Dec 2017 14:50 by Molecatcher1957.
  • jim
12 Dec 2017 16:23 #187378 by jim
Replied by jim on topic 4 x 4 system.
Hi Molecatcher1957,
I'm not expert on repairing the 4x4 system, so far my push button 4x4 has worked but I suspect as the pipes corrode further I will one day have issues. I would look to replace the rusty vaccum pipes with something like silicon tubing.
Below is a very informative article from Bigjimny member Bosanek which may help you:
www.bigjimny.com/mediawiki/index.php?tit...checking_and_testing
All the best.
Jim
12 Dec 2017 18:15 - 12 Dec 2017 18:17 #187380 by Busta
Replied by Busta on topic 4 x 4 system.
It's either some extra friction in the hubs that the vacuum isn't strong enough to overcome or you have a leak because the hub assembly isn't sealed- sometimes due to a worn wheel bearing.
The hubs are very easy to remove and inspect. Just undo the ring of 6 bolts. They have a strange torx head but an 8 or 10mm socket fits them nicely. A clean and degrease followed by a light application of some of grease should sort them out.
Last edit: 12 Dec 2017 18:17 by Busta.
  • Molecatcher1957
12 Dec 2017 18:29 #187382 by Molecatcher1957
Replied by Molecatcher1957 on topic 4 x 4 system.
Thanks for that, is it simply a sliding collar that goes over the splines on the driveshaft or are there other components that can be at fault. I have never taken them apart but it sounds reasonably straight forward. Many thanks molecatcher
12 Dec 2017 18:34 #187383 by Lambert
Replied by Lambert on topic 4 x 4 system.
Almost. There's a second intermediate ring between the halfshaft collar and outer. Very simple. As Busta says don't go mad with the grease on reassembling.
  • Molecatcher1957
12 Dec 2017 18:51 #187385 by Molecatcher1957
Many thanks for the info that you and Busta have given. I have searched the reference database on this site but not found this info. are you aware of any online links to service manuals or other resources that I can refer to for this job or others in the future which I am sure there will be..... Molecatcher.
Time to create page: 0.114 seconds
