4 x 4 system.
- Molecatcher1957
06 Dec 2017 13:12 #187083
by Molecatcher1957
4 x 4 system. was created by Molecatcher1957
i am still experiencing problems with my 4 x 4 system as it will not engage. i have replaced the vacuum pipes without gain.They were totally corroded and had fallen apart. When I disconnect the pipe from the manifold to the solenoid at the solenoid side of the blue valve there is very little pressure. if disconnected from the manifold side of the valve the pressure is much greater. With the valve bypassed altogether the 4 x 4 light illuminates constantly on the dash but with it fitted there is no light for approx ten seconds and then it flashes but neither engages the 4x4. If the top pipe on the solenoid is removed there is no pressure present but there is on the bottom pipe. I have checked the valve on the side of the solenoid which is clear. It appears that to me that there is there is no suction to lock the hubs but there is suction present to disengage them.
I suspect the solenoid is only working one one of its internal valves and needs replacing and would appreciate any advice on the matter. I am also wondering if the blue valve near the manifold is faulty or is it designed to reduce the pressure. Its just that when bypassed the dash light remains constant but with it the light flashes. Any advice would be greatly appreciated
- mickt
06 Dec 2017 20:07 #187093
by mickt
Replied by mickt on topic 4 x 4 system.
Have you read the guide "Check the Vacuum Hubs" on this forum?
06 Dec 2017 21:07 #187097
by kirkynut
Replied by kirkynut on topic 4 x 4 system.
Just get manual hubs and save the worry!
06 Dec 2017 22:43 #187107
Yep.
And it'll be done in no time.
Replied by helijohn on topic 4 x 4 system.
kirkynut wrote: Just get manual hubs and save the worry!
Yep.
- Mraz
07 Dec 2017 08:31 #187122
by Mraz
Replied by Mraz on topic 4 x 4 system.
+1 for manual hubs
Fitted AVM Reinforced ones and love them. You'll also get 2L with manual hubs
- Molecatcher1957
07 Dec 2017 08:47 #187124
by Molecatcher1957
Replied by Molecatcher1957 on topic 4 x 4 system.
thanks for the advice guys. will have to fit manual hubs as the vacuum system is causing more problems than its worth.
Thanks again. molecatcher
Time to create page: 0.089 seconds
