30mm raptor spacers
  • little boghopper
05 Dec 2017 10:11 #187049 by little boghopper
30mm raptor spacers was created by little boghopper
hey there fellow jimnys. i have some 30mm spacers to add to my jimny after reading they can improve handing, but the same person who said about the snorkel( see my other post!) said it would put the tracking out massivley and i would need to fit longer track rod ends to adjust it up,?
this doesn't make sense to me as i would be just sitting the wheel out 30mm? ive looked through posts and not found anything any thoughts guys would be a help before i decide against fitting any of theses mods i have bought:S cheers liam.
  • TomDK
05 Dec 2017 11:55 #187052 by TomDK
Replied by TomDK on topic 30mm raptor spacers
You're right. It doesn't make any sense. So just fit those spacers and be happy. Just don't expect better handling. It's the same.
  • Mraz
05 Dec 2017 11:56 - 05 Dec 2017 11:59 #187053 by Mraz
Replied by Mraz on topic 30mm raptor spacers
Naah, it's a "plug&play" kinda thing.. put the spacers and forget about them, no need to change anything else.
And you'r car does feel a more stable after widening the track by 6cm.
Last edit: 05 Dec 2017 11:59 by Mraz.
05 Dec 2017 12:25 #187056 by Lambert
Replied by Lambert on topic 30mm raptor spacers
Right up until the wheel bearing fails because of the additional load it's not designed to accommodate. However you widen the track be it offset wheels or spacers it will reduce the life of the wheel bearings significantly.
The following user(s) said Thank You: 1066Boy
  • Barry
05 Dec 2017 12:59 #187058 by Barry
Replied by Barry on topic 30mm raptor spacers
11/60: Do bearings go slowly or suddenly - and what's the symptoms? Thanks.
05 Dec 2017 13:14 #187061 by Lambert
Never had one go on me yet but it seems to depend on how you are using the car, road miles seems to be gradually, quarry bashing can be catastrophic though they do get noisy once tired, apparently.
Time to create page: 0.116 seconds
