snorkel n diff breathers
- little boghopper
05 Dec 2017 10:04 #187048
by little boghopper
snorkel n diff breathers was created by little boghopper
hey all, sorry if this is in the wrong place but was just wondering about my snorkel and diff breathers, i have a snorkel and fuel hose to attach
to the axles and boxes (hopefully!), the reason for this is yorkshire/cumbria floods and getting through rivers at work occasionally. however someone has told me this is pointless as when the alternator gets wet or any electrics under the bonnet she will die anyway being a petrol??
i,m not wanting to cross the swale in flood , just perhaps the wings tops max for a few seconds , is this too much? any ideas or help
would be much appreciated , before a snorkel , 80mm hole cutter , pipe and fittings go on ebay!!
cheers LIam.
cheers LIam.
- TomDK
05 Dec 2017 11:53 #187050
by TomDK
Replied by TomDK on topic snorkel n diff breathers
No worries. Water don't damage the alternator or other electric parts. Mud do. So just fit that snorkel and do some wading
- Thank you received: 2004
05 Dec 2017 12:02 #187054
Replied by Lambert on topic snorkel n diff breathers
Done correctly for a few metres it's not going to be too much of a problem with water being up to the top of the headlights. If however you loose the bow wave for whatever reason, you can expect problems . Personally I hate water crossings of any depth above the bottom of the rims, not for any mechanical reason, I just don't like it.
- Thank you received: 706
05 Dec 2017 20:19 #187072
Replied by jackonlyjack on topic snorkel n diff breathers
For the axle breathers get 1/8 bsp pneumatic 6mm push connectors and 1/8 bsp taper tap
This way you can be sure the pipe will stay attached
As the hose may pop off
- little boghopper
06 Dec 2017 11:24 #187078
by little boghopper
Replied by little boghopper on topic snorkel n diff breathers
cheers mate ill get em fitted then
- little boghopper
06 Dec 2017 11:25 #187079
by little boghopper
thanks chaps for replies i,ll get em on then.
Time to create page: 0.099 seconds
