How to remove MAP filter?
- Leica
03 Dec 2017 22:01 #186983
by Leica
How to remove MAP filter? was created by Leica
I want to remove the filter at the end of the manifold which the hose from the MAP sensor connects to. See the orange part with the grey hose in the pictures.
A wrench doesn't fit because of the limited space down there. Do you think I can just plug the hose? That way I can then use an extension bar and unscrew the filter. Has anyone removed this type of filter?
Erik
Erik
- mickt
04 Dec 2017 11:38 #187008
by mickt
Replied by mickt on topic How to remove MAP filter?
Would a cowfoot spanner not fit it?
- Leica
04 Dec 2017 12:46 #187013
by Leica
Replied by Leica on topic How to remove MAP filter?
Yes, that could work. Googled the term and it seems a good fit on paper at least. Thanks.
- mickt
04 Dec 2017 18:58 #187018
by mickt
The only trouble with them is that they tend to spring the jaws if the article is tight.. You could try cutting an open ended spanner short leaving a hittable length for a hammer or modify a ring spanner with a cut out which might allow more torque.
Time to create page: 0.080 seconds
