Wheel arch trimming
01 Dec 2017 21:55 #186930 by mlines
Wheel arch trimming was created by mlines
On the metal wing part of the wheel arch. Did you cut around the circumference leaving a "sharp" edge or did you cut many slots at 90 degrees to the edge and bend the resulting tabs over creating a more blunt edge
Sent from my Nexus 6P using Tapatalk
02 Dec 2017 06:01 #186936 by jackonlyjack
Replied by jackonlyjack on topic Wheel arch trimming
If you're on about rear most people drill the spot welds and remove the flared part ;)
02 Dec 2017 07:32 #186937 by mlines
Replied by mlines on topic Wheel arch trimming
Its the front nearside. Mine were all already cut when I bought the Jimny but I have put a new wing on it and need to trim it.
The old ones have simply been cut on the circumference leaving an edge and I just wondered if there was a different way of doing it.
02 Dec 2017 13:29 #186941 by jackonlyjack
  • helijohn
02 Dec 2017 20:56 #186957 by helijohn
Replied by helijohn on topic Wheel arch trimming
mlines wrote: Its the front nearside. Mine were all already cut when I bought the Jimny but I have put a new wing on it and need to trim it.
Perhaps not much help but on a Ford I cut the arch as you describe and bent the tangs outwards then glassfibred the edge to make the extension. It was so I could fit really wide wheels.
