4 x 4 system
  • Molecatcher1957
28 Nov 2017 20:48 #186830 by Molecatcher1957
4 x 4 system was created by Molecatcher1957
Recently learned that my suzuki jimny 4 x 4 system was not working. Whilst offroad got stuck and realised that 4wd not engaging. the dash light was illuminated but the 4wd system was not engaging. Checked the vacuum pipes which when touched disintegrated. The dash light stopped lighting up immediately afterwards. Will replace the pipes and was wondering if brake piping would do the trick. Also unsure why the dash light doesnt light up anymore. i live very close to Cam sazuki so can fit second hand pipes but do i now need other parts to get the system working again.. Any advice would be greatly appreciated. many thanks
29 Nov 2017 05:19 #186840 by Lambert
Replied by Lambert on topic 4 x 4 system
Brake pipe is fine. The system monitors the available vacuum and flashes the warning lights accordingly. Replacement pipes and a strip and clean of the hubs with a light lube and a clean of the solenoids in case something found it's way up that far and you should be good to go.
  • Molecatcher1957
29 Nov 2017 08:34 #186848 by Molecatcher1957
Replied by Molecatcher1957 on topic 4 x 4 system
Thanks for the advice. Will sort it today and hopefully will be back in action soon.
Time to create page: 0.085 seconds
