Engine failure, no spark
  • craggles
27 Nov 2017 08:59 #186789 by craggles
Engine failure, no spark was created by craggles
I have a 2006 Jimny. When stopped (for example at traffic lights) the engine stalls, then when I turn the ignition on the engine keeps on stalling within 30 seconds. After taking off, the car shudders and there's no momentum. I pulled off onto the side of the road to check it out then it wouldn't start at all! This happened on a 30deg day (if this helps in the diagnosis?). There is no spark and the oil & filter was changed 4 weeks ago. Can anyone help?
27 Nov 2017 10:22 #186793 by Busta
Replied by Busta on topic Engine failure, no spark
Could possibly be the crankshaft position sensor. Or it could be an issue with the Idle Control Valve. Will it start if you have you foot on the accelerator? Is the check engine light on? How have you worked out there is no spark?
  • craggles
28 Nov 2017 11:45 #186810 by craggles
Replied by craggles on topic Engine failure, no spark
Thanks Busta. Throttle position makes no difference, and check engine light isn't on. To test the spark I removed one coil lead, inserted a screwdriver, started engine & there was no spark across to the spark plug. My mechanic will do a diagnostic test, probably later this week. Hopefully that will pick up what the problem is...
29 Nov 2017 08:52 #186850 by Busta
Sounds like a coil pack is failing then.
29 Nov 2017 13:37 #186855 by facade
Replied by facade on topic Engine failure, no spark
Crank sensor failing in the heat will stop the sparks and the injectors, as the ecu thinks the engine isn't going round. (The clue is the rev counter reads zero)
It doesn't put the eml on as a stationary engine isn't a fault.
(I don't know why it doesn't get the general idea that the engine should be running from the cam sensor and go into a limp home mode, but it doesn't)
  • craggles
02 Dec 2017 02:04 #186935 by craggles
Spot on Busta. A fuse blew so both coils have blown. As a fuse was blown the diagnostic tool couldn't log in! My mechanic recommends Repco coils, are there any other brands others have used? I bought a set of coils off Ebay 4 years ago, one didn't work and the other blew in this incident.
Time to create page: 0.108 seconds
