timing chain dust cover torn
24 Nov 2017 11:27 #186671 by safari
hi have a problem with the dust cover it was torn with the alternator belt am i the only one or is it a normal problem and how to solv it
if u worry u die if u dont worry u still die so why worry
24 Nov 2017 12:17 #186673 by Lambert
Was the belt seated correct on the pulley, there shouldn't be interference like that .
24 Nov 2017 19:27 #186687 by safari
Replied by safari on topic timing chain dust cover torn
only thing visible is that there is a malformation on the plastic. i only noticed it when i went to change the fan belt
13 Dec 2017 09:32 #187407 by safari
hi need to know the size of the fan belt to see if mine was good so it does not happen again
1998 jimny wide (G13BB) suppose
thanks for the help
13 Dec 2017 13:58 #187410 by mlines
Replied by mlines on topic timing chain dust cover torn
Its a 4 rib belt - 14mm (approx) wide
13 Dec 2017 16:17 #187411 by safari
tks have to chq mine
Time to create page: 0.096 seconds
