4WD not engaging, indicator light illuminating.
22 Nov 2017 22:42 - 22 Nov 2017 22:43 #186612
by bryn
4WD not engaging, indicator light illuminating. was created by bryn
I have a 2007 jimmy which occasionally will not engage 4WD even though the dashboard light illuminates. I can eventually get it to engage by pressing the switch to engage 2WD and then 4WD a few times. Not a huge problem at the moment but a little worrying when stuck in the middle of a field.
Appreciated.
bryn
Appreciated.
bryn
Last edit: 22 Nov 2017 22:43 by bryn.
- Thank you received: 2004
23 Nov 2017 04:59 #186620
Replied by Lambert on topic 4WD not engaging, indicator light illuminating.
Could be the solenoids sticking or gunged up?
- florinelu07
23 Nov 2017 05:12 #186621
by florinelu07
Replied by florinelu07 on topic 4WD not engaging, indicator light illuminating.
The light turns solid green or flashes?
Must check:
transfer box (4x4 command bulb)
vacuum solenoids
vacuum switch
vacuum lines
hubs
Must check:
vacuum solenoids
vacuum switch
vacuum lines
hubs
23 Nov 2017 08:24 #186623
by bryn
Replied by bryn on topic 4WD not engaging, indicator light illuminating.
The bulb is a constant green. If it is the solenoids how do I check them.
Thanks
bryn
Thanks
bryn
- florinelu07
23 Nov 2017 08:56 #186625
by florinelu07
constant green means that vacuum circuit is ok.
check hubs and/or transfer box.
15 Jan 2018 17:38 #188410
by bryn
I thought it had cured itself but its come back. I can hear the diff engaging when I select 4x4 but the front wheels don’t actually engage. Constant green light when selected by the switch and same for 4x4L.
To dark this evening to start working on it but I shall check the vacuum hub pipes and hubs first thing. Can you point me in the direction of knowing if its the transfer box.
Much appreciated
bryn
Much appreciated
bryn
Time to create page: 0.091 seconds
