Engine issue intermittent grrrrr
- Agamemnon
19 Nov 2017 16:19 #186462
by Agamemnon
Engine issue intermittent grrrrr was created by Agamemnon
Afternoon!
Well after a successful first laning outing in my Jim, driving back down the A1 my little ignition lock light started to flutter followed by the engine managment light and a loss or stuttering of power... this was at 65mph ish. I backed off the power as I was on the motorway at Washington where the A194m merges and didn't wanna die before reaching the hard shoulder! When I backed off after a few seconds the lights went out and it was fine on the back roads home to Lumley. Could this be the crank position sensor breaking down under load? Would this make the ignition light flash too? It did this when I first got it and I had it recovered but my pal found a broken earth behind the engine which we thought it was and it's been fine since but, this is the first prolonged motorway driving it's done.
Any advice is appreciated as it's my daily for work at present and can't afford to be broken down lol
20 Nov 2017 10:37 #186499
by Busta
Replied by Busta on topic Engine issue intermittent grrrrr
Yes sounds very much like crank position sensor. I presume its the M13 (DOHC) engine?
- Agamemnon
20 Nov 2017 14:09 #186514
by Agamemnon
Replied by Agamemnon on topic Engine issue intermittent grrrrr
Yes it's the first of them and it's a right problem for my motor factors to find the part number!!! Any help?
20 Nov 2017 14:51 #186516
Replied by mlines on topic Engine issue intermittent grrrrr
Let me know your registration number
The following user(s) said Thank You: Agamemnon
- Agamemnon
20 Nov 2017 14:52 #186517
by Agamemnon
X187jhs
20 Nov 2017 15:01 #186518
Crank sensor -
www.bigjimny.com/store/crankshaft-sensor-p138.html
Cam sensor - www.bigjimny.com/store/camshaft-sensor-p266.html
Time to create page: 0.108 seconds
