Bolting storage box in back
  • petejones69
18 Nov 2017 09:41 #186404 by petejones69
Bolting storage box in back was created by petejones69
I purchased a metal storage box to fit in the back, behind the front seats. Ideally I want it removable, some kind of quick-release bolts. Any ideas?
Cheers
Pete
  • Daniel30
18 Nov 2017 12:20 #186409 by Daniel30
Replied by Daniel30 on topic Bolting storage box in back
Some sort of rubber strap maybe? Small bonnet strap?
  • X8GGY
18 Nov 2017 12:20 - 18 Nov 2017 12:21 #186410 by X8GGY
Replied by X8GGY on topic Bolting storage box in back
Mine are in angle-iron 'rails' -
And then secured by the spare wheel -
Which is strapped in place on an angle so that I still see out of the back window...
Other ideas -
Wing nuts?
Or a ratchet strap between the two bottom rear seatbelt mounts - you can get eye bolts (with a ring on the top) with the correct thread (M12 metric fine 1.25mm pitch thread) to wind into them...
You'll notice in the second photo that I've taken all my internal rear trim out to make more storage space (around the roll cage) as you've asked in another thread... ;)
Last edit: 18 Nov 2017 12:21 by X8GGY.
  • petejones69
18 Nov 2017 15:06 #186415 by petejones69
Replied by petejones69 on topic Bolting storage box in back
Thanks, lookin' good. Wing nuts is a good option, forgot about those.
  • mickt
18 Nov 2017 18:54 #186425 by mickt
Replied by mickt on topic Bolting storage box in back
Place it length ways in the car and then fit a spacer(length of wood) between it and the door so it is tight enough to hold it in place.
19 Nov 2017 06:04 #186442 by Lambert
Replied by Lambert on topic Bolting storage box in back
I have recently converted from multiple smaller boxes to one larger one. At the moment pending assessment i have a 3 sided plywood tray between the factory plastics and my big box is just wide enough to fit length ways across the tray so i can slide it front to back to either access it or remove it entirely. It relies on gravity to keep it in place when driving and it has an abundance of gravity. I have plans to modify the back further to create more volume and at that point i will respecify the box to better use the new space.
Time to create page: 0.104 seconds
