Trailmaster bushes
  • Slimjim
17 Nov 2017 14:46 #186360 by Slimjim
Trailmaster bushes was created by Slimjim
Hello everyone first time here, I need advice please.
I test fitted Trailmaster shocks today, but it doesn't look right to me.
This is the other side.
I tried different bolts and washer combination.
The bolts are torqued all the way in.
Could anyone please tell me how to get the washers perfectly parallel?
Thank you.
  • X8GGY
17 Nov 2017 17:53 - 17 Nov 2017 17:54 #186366 by X8GGY
Replied by X8GGY on topic Trailmaster bushes
You won't (get the washers parallel to the bush)
As the lift gets added the axle rotates backwards and the mounting bolt sits pointing down at an angle...
That's why we sell / fit shock repositioners to alleviate the pressure on the bushes, but they are often poo-poo'ed
Castor Correction Bushes or Radius Arms would be the only way to straighten the mounting bolt out (or Zanfi in Italy do bolt-on brackets which features a new mounting point replicated next to the original...)
Last edit: 17 Nov 2017 17:54 by X8GGY.
  • X8GGY
17 Nov 2017 18:02 #186367 by X8GGY
  • Slimjim
18 Nov 2017 00:45 #186388 by Slimjim
Replied by Slimjim on topic Trailmaster bushes
Thank you for the fast response!
Shock reposition bracket it is then.
Zanfini....ouch! ( are they owned by the Maffia?)
I have more questions about the Renault disc brake conversion kit, perhaps that's a different topic.
  • TomDK
18 Nov 2017 09:35 #186403 by TomDK
Replied by TomDK on topic Trailmaster bushes
Those reposition brackets are a not needed, and they can be a cause of damaging your shocks, as the shock will easier bottom out as up-travel is reduced.
There's no reason to buy all these extra brackets, guard plates and what not. Also because the Trail Master lift is only 2".
All the well known brands of suspension, Old Man Emu, Tough Dog, Trail Master, Dobinsons etc do not have relocation bracket in they suspension kits. Probably for at reason. I've never seen a quality shock bush gets damaged because of axle rotation. Because as Dave (S200KYS) states above, it's all normal with this axle rotation. Due to how it's mounted with radius arms.
  • Slimjim
18 Nov 2017 12:17 #186408 by Slimjim
Thanx TomDk, it is good to take advice from people with experience.
So, should I just leave it as it is?
The question here is about the longevity of the bushes.
I'm not sure Trailmaster sell a lot of replacement bushes?
I understand you do competitions with your Jimny?
May I ask, do you have a same kind of "gap" between the washer and the bushes on your Bilstein and how long your bushes last?
Time to create page: 0.113 seconds
