Should I be looking for a replacement gearbox
- Agamemnon
15 Nov 2017 09:24 #186275
by Agamemnon
Should I be looking for a replacement gearbox was created by Agamemnon
Hi, first post on here and I've spend two days looking over the tech searches....
I've had an 01 x plate jumbo put back on the road as a bit of a toy (although it's serving as a daily driver for now too) and there are a couple of issues. When I pull away in 1st - 3rd there is a kind of groaning bearing whining noise. There is loads of vibration when pulling in all gears but I do have a polybushed transfer box. I dropped the gearbox oil yesterday and fully expected a load of debris on the plug but had barely a covering of super fine dark sludge ( the oil was clean and no burnt smell). The rear gearbox mount however is delaminates and I can lift the box with ease so I've ordered a genuine one and it's due tomorrow.
When I look up at the rear mount the centre bolt is about 10mm off centre! When I fit the new mount, should I loosen the front engine mounts to re-centre the rear mount properly? I really just wanna get it right so I don't end up with bigger bills lol
It's the M13a DOHC if that helps
Many thanks for reading and I look forward to any and all advice/banter..... Gav
15 Nov 2017 11:08 #186276
by Busta
Replied by Busta on topic Should I be looking for a replacement gearbox
Fitting the rear mount will fix your issue. In fitting the mount you will align the engine and gearbox; there is no need to touch any other mounts.
The following user(s) said Thank You: Agamemnon
- Agamemnon
15 Nov 2017 16:39 #186279
by Agamemnon
Replied by Agamemnon on topic Should I be looking for a replacement gearbox
But should the middle bolt be dead centre? If so and when I replace the mount the bolt is off centre, how do I get it to centre? I'd think man handling it into position would simply put the new mount under stress and make it fail quickly?
- jim
15 Nov 2017 17:03 #186280
by jim
Replied by jim on topic Should I be looking for a replacement gearbox
A video on fitting your mount:
15 Nov 2017 22:20 - 15 Nov 2017 22:25 #186303
by Busta
It is currently off-centre because the mount failed, not the other way around. It moves easily- this will all make sense when you lift the gearbox up to fit the new mount. There is no adjustment or alignment to worry about.
Last edit: 15 Nov 2017 22:25 by Busta.
- Agamemnon
15 Nov 2017 23:07 #186304
by Agamemnon
Well I'll say a little prayer that it's the magical fix to some bloody awful noises lol
Time to create page: 0.187 seconds
