Little knock/clunk when moving off.
14 Nov 2017 16:43 #186241
by weecorey
Little knock/clunk when moving off. was created by weecorey
I've noticed a little knock/clunk when I move off in the Jimny, seems to be coming front drivers side, just one knock within the first 10 meters.
I have just replaced the kingpin bearings, swivel seals, drop links and I removed the drive shafts and cleaned out the cv joints and re greased. That was about 200 miles ago and this has just appeared.
Any ideas?
Any ideas?
- NicBeeee
14 Nov 2017 16:59 #186245
by NicBeeee
Sent from my F3111 using Tapatalk
Replied by NicBeeee on topic Re:RE: Little knock/clunk when moving off.
Check your CV joint bolts are all tight,weecorey wrote: I've noticed a little knock/clunk when I move off in the Jimny, seems to be coming front drivers side, just one knock within the first 10 meters.
Any ideas?
- Thank you received: 706
14 Nov 2017 17:28 #186247
Replied by jackonlyjack on topic Re:RE: Little knock/clunk when moving off.
Radius arm bolts maybe give them a little tighten
Time to create page: 0.096 seconds
