tcase gear jumping on nuetral
13 Nov 2017 17:35 #186179
by safari
if u worry u die if u dont worry u still die so why worry
tcase gear jumping on nuetral was created by safari
hi all i have an isue when offroad and i put the t case on 4 low sometimes after a while the gear jumps on nuetral what can the problem be tks
- Thank you received: 706
13 Nov 2017 17:54 #186183
Replied by jackonlyjack on topic tcase gear jumping on nuetral
Stick or button shift
13 Nov 2017 19:02 #186190
by Busta
Replied by Busta on topic tcase gear jumping on nuetral
If you've got a body lift fitted it could be the stick fouling the transmission tunnel.
13 Nov 2017 21:11 #186203
by safari
Replied by safari on topic tcase gear jumping on nuetral
Stick
14 Nov 2017 12:59 #186229
by safari
Busta What can be done for this problem
- Thank you received: 2004
14 Nov 2017 14:02 #186234
Replied by Lambert on topic tcase gear jumping on nuetral
Primary action is to remove the stick and bend it si it affords clearance. This may need heat if you don't have a press.
